This came out of an 084, flywheel side. Local shop here asked if I had ever seen any others like this.
Totally broken away from the outer rim all but about 25%.
Only thing I can think of is either serious heat cycling crappy aftermarket steel or something come loose from the bearings and gave it a good battering?
I had a seal in an 044 where the rubber was completely Gone...just the metal. Customer kept wondering why it would run away when it finally took a throttle.
