Buy Used Saws CCC Ebay Store
Things I have learned about the MS362c
Discussion in 'Chainsaws' started by Stevetheboatguy, Jul 11, 2019 at 11:13 PM.
  1. Stevetheboatguy
    Stevetheboatguy Pinnacle OPE Member
    Feb 6, 2017
    409
    1,654
    203
    Nw IL
    Ok this is what I have learned about the ms362c. I am not setting out to bash it. It does have a few good qualities.
    #1 They sell really well.
    #2 Incredibly consistent.
    #3 Balance great with a 20". Especially if you want to throw one.
    #4 Plug holes strip real easy on them. (Not by myself but fixed for others)
    #5 P&C change can be done in 30min or less w/o power tools on a clean saw. (Have had plenty of experience on this one actually lost count)
    #6 They sell really well. Or did I say that already.......
    #7 Hyway brand cyl runs as well as factory. Although their pistons need some extra clearancing or they WILL hit the crank webs. (Has happed on all four I have used) (staying with oem now)
    #8 Timing advance and muff mod help starting, idle and throttle response. But don't do much for power increase.
    #9 Av is great. Really softens the impact when it hits the ground.
    #10 Tried one for a boat anchor last week when fishing. Is a little light but worked ok.
    #11 Fuel solenoids suck.
    #12 I still don't like running them. Have one ugly one I keep on hand to remind me of all the above.
    So that's what I have. Honest truth. Wish I could have found the secret that a few guys have. The one that wakes them up. But in all my dinking around I didn't find anything that made a huge gain. I'd love to find it but It's back to work on Monday for me. No more time to play with saws for a while.
    Steven
    MG porting, drf256, P.M.P. and 9 others like this.
  2. rumatt
    rumatt Well-Known OPE Member
    Jun 17, 2018
    103
    234
    88
    US
    Well played sir.
    MG porting and Stevetheboatguy like this.
  3. Basher
    Basher Pinnacle OPE Member
    Jan 16, 2016
    859
    2,540
    255
    Canada
    I am still running my carbed version, nothing special about it,nothing to rave about. Starts easy, runs fine, pulls a 20" just fine, cuts everything I need in its class. Need a longer bar then use one of my bigger saws til I max out at 60".
  4. sawmikaze
    sawmikaze The 462 is light
    4,344
    21,014
    517
    steeltown
    This is the most blasphemous thing I've read on OPE forum.
    MG porting, deye223, P.M.P. and 6 others like this.
  5. TreeLife
    TreeLife I like saws
    Jan 24, 2017
    2,789
    11,601
    368
    Berkshire County, Massachusetts
    Lol I'll bash it, it's one of the worst saws stihl has ever made. All of the preceding models were much stronger and not as complex.
    Stevetheboatguy likes this.
  6. Goattownwoodcutter
    Goattownwoodcutter Well-Known OPE Member
    Jul 6, 2019
    22
    127
    58
    GA
    I have the carb version 362, really like it. Ran it stock for several years with 25" bar, did fine. Just had @huskihl do a few tricks to it. It's a different saw now.
  7. Lightning Performance
    Lightning Performance Pinnacle OPE Member
    Jan 26, 2016
    3,328
    6,037
    305
    361 to 362 but no convert. I'll bash it why knot.
    Mine is modded with adjust screws, base gasket deleted, one holed muff, timing tipped, non HD filter work saw. Handles a twenty with eight pin or twenty four with seven if it is a long walk. Balances nicer with a twenty four than my treesixone. Zero complains really.
    The same thing done to my 361 is a high winding nasty piece of work you might have thought was ported. Plus it is better balanced and lighter. The 361 AV can be better and mine is. The 362 has more bottom end but lacks rpm to limb fast imo.
    The 362II is a betterer, lighter an a more capable saw than my version one saw given the same mods. That said "my" 362 still feels like a lump of *s-word in my hand with an 18" 8p. Your mileage may vary.
    MG porting likes this.
  8. sawmikaze
    4,344
    21,014
    517
    steeltown
    You guys are taking the awesome away.
    junkman, MG porting, P.M.P. and 6 others like this.
  9. DND 9000
    DND 9000 Super OPE Member
    Feb 6, 2016
    351
    769
    188
    Germany
    Update the solenoid valve to the newer white one on existing carburetors with originally a black valve. Use the update kit 1140 007 1802, including the new pickup body 0000 350 3518 (orange), and white solenoid valve 0000 120 5104. (Usable for C1Q-S235, C1Q-100357 carburetors, the newer ones already have the updated parts) After installation, don`t forget to recalibrate.
  10. Lightning Performance
    Jan 26, 2016
    3,328
    6,037
    305
    Muh bewd hurtsed :confused:
  11. cus_deluxe
    cus_deluxe ONE OF THE WORST!!
    Jan 3, 2016
    2,485
    9,006
    378
    Michigan
    huskyboy, MG porting, Cobby08 and 7 others like this.
  12. sawmikaze
    4,344
    21,014
    517
    steeltown
    I thought you only had to do the calibration if you swapped coils ?
    I've put white solenoids in the 261s and 362s with that orange fuel filter and they run perfect with no calibration.
  13. sawmikaze
    4,344
    21,014
    517
    steeltown
    The 362c used to be a perfect 2 saw plan with the 044.
    What the hell happened ?????
  14. sawmikaze
    4,344
    21,014
    517
    steeltown
    I wish I could tag mike from maine.
  15. Lightning Performance
    Jan 26, 2016
    3,328
    6,037
    305
    @sawmikaze
    Is this the new Rachel's pics thread? "Why, yes...yes it is my good man."
  16. Lightning Performance
    Jan 26, 2016
    3,328
    6,037
    305
    Autocorrect.
    Muh head hurted.
    MG porting and cus_deluxe like this.
  17. Stevetheboatguy
    Feb 6, 2017
    409
    1,654
    203
    Nw IL
    Yep. Been there a few dozen times. Something that shouldn't be needed or should be more reasonably priced for a consumable item. They fail super easy and often. Anything makes it past the filter and they are usually toast. I will usually replace the fuel line at the same time as the solenoid. A rotten or gummy fuel line will toast the new solenoid in a hurry.
    Never had a regular carbed 362. Would definitely be my choice. Going to try and convert one to non mtronic this fall/winter.
    Steven
  18. sawmikaze
    4,344
    21,014
    517
    steeltown
    Almost 100 bucks for a white solenoid at my dealer..they sure are proud on em'
    It says STIHL on it so it's clearly the best.
  19. Stevetheboatguy
    Feb 6, 2017
    409
    1,654
    203
    Nw IL
    Buy the kit with the filter. It's half the cost. Pn# 1140 007 1802. Unless it's a regional thing.
    Steven
    MG porting, RI Chevy and sawmikaze like this.
  20. Lightning Performance
    Jan 26, 2016
    3,328
    6,037
    305
    Guess mine needs port work to feel the greatness, ya think?:BangHead::BangHead::BangHead: feeling better now:banana:
Loading...
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
