The Swap Meet Thread
jacob j.
Lord of Cargo Pants
8:57 AM
Coastal Oregon
Hi guys Im in need of a coil for one of my main saws Makita 7900 oem or if you have a 272 I will be happy to make it work.
Had the wire brake off yesterday. It was barely hanging on the insulation was cracked through had it liguid taped. I was hard on it taking the plug out before and it finally gave in.
Is the coil wire in those replaceable?
4:57 PM
1507506792569767589248-jpg.91505
As asked by the gentlemen above, replace the plug, keep the coil?!
If the wire is not detachable:
- cut it while leaving enough on the coil
- push a heat shrink hose of correct size over the wire
- connect the new wire/lead by twisting a thin enough wood screw in it, half way
- cut of the screws head
- twist the screws end into the coil side wire
- pull the heat shrink hose over the connection spot and heat it up
You can go double or triple on the shrink hose to make the connection more durable.
There are also heat shrink hoses that are laced with glue on the inside.
Make sure You figure out the total wire length and where to place the connection/fix before You cut off the original lead.
Replacement ignition wires and heat shrink leads can be had fairly affordably on eBay.
You might also be able to source these at a local shop of Your choice.
The shrink hoses can be had at various shrink ratios, 2:1 without glue on the inside is the most affordable.
Mere examples:
http://www.ebay.com/itm/328tlg-150t...hash=item2cbe993b40:m:mkjcWigPL97JXfqhderi8KQ
http://www.ebay.com/itm/LAWN-MOWER-...410114?hash=item212f4bafc2:g:SQwAAOSwu4BVj~9-
I know this might sound stupid, but I used this method as a temporary quick fix that held up much longer than expected, granted not on a chainsaw though.
Sty57
10:57 AM
Land of Cheese & Beer
http://www.ebay.com/itm/OEM-Dolmar-...582873?hash=item5acf191019:g:ccAAAOSwLEtYhAYK
dolmar Part # 038143030 it shows you can buy just the lead so you should be able to replace it.
4:57 PM
Back in business the saw is. I went the cheap route found some wire that was same gauge measured and solder. Also put put a couple pieces of shrink wrap on.
Thanks @Stump Shot and @Wilhelm seems as good as new.
There You go!
Considering that the lead got fixed, I'd get me a spare one just in case.
Glock37
11:57 AM
Monroeville Pa
Looking for 2 oem stihl ms 660 cranks with 10 mm flywheel thread
Got money to trade
Mycamaro_68
By guess and by golly
10:57 AM
Cedar Rapids, IA
I am looking for an air filter cover and a clutch cover for an 028wb. They don't need to be NOS quality but preferably not completely roached either. Let me know if anybody has something hanging out in there parts pile. Thanks.
brandonstclair20
11:57 AM
Starkville
For the bump, anyone interested in a husqvarna 545 project?
bulletpruf
4:57 PM
San Antonio, TX
Looking for Jonsereds 110/111 parts. Need pretty much everything.
Also need a piston and jug for Stihl 048.
