psuiewalsh
Basement Bodging
- 3:47 AM
- Dec 23, 2015
- Nottingham,pa
I tried to test fit 372 and 572 wrap. They are too short. Maybe 390 or 395 would be closer?
Why not ask our HLSupply guys to get some AM large frame Dolmar/Makita full wraps made?!
I guess it will come down to the extent of demand.
I'm looking for a Dolmar 64xx/73xx/79xx full wrap handle. Dang those things are expensive, which is why I don't have one yet.
And next year will be the 900i build off. Make it official @Mastermind, so the demand will be so great Stihl will be forced to make it.I think Mastermind's upcoming shindig is responsible for doubling the demand of Dolmar/Makita parts within the last year.
Looking for parts for MS250. Used and serviceable are ok. Not trashed
Clutch cover
Bar adjuster
Bar studs and nuts
Bar
Chain
Chain guides
Clutch sprocket
Looking for an M5x35 screw and spacer to hold the hug down on a 550xp
Box o saw only had 3 for some reason.
Usually I put big 16 nails and bend them to fit in the webbing and use auto panel bond to fix plastics. Make sure you do a good prep first.Anyone have a solid 3210 brake flag #503 13 67-03 for sale or trade?
Mine is structurally solid but has been melted by the muffler at some point. View attachment 189176Otherwise I guess I could build up the area with JB and sand it.
Yeah, that flag is deformed at that burned spot...., possibly the result of a long flush cut of a stump at some point..., or the deflector being loose, or both? And yeah, may want to get rid of the tabs on the deflector or at least bend them forward a bit..., or mod it with a tube outlet if you have the means or someone to do it for you.
