The Small Dolmar/Makita Thread..Max 50cc class
Simondo
3:33 PM
UK
I personally spend most of my time using saws from the smaller Dolmar/Makita cc class .
From the ps-32 on up to the ps 5105 .
Likes..Dislikes...Information ....Etc.
If you have a interest in them , then this thread is for you.
Il start the ball rolling .....
The start point...Ps 32 ...
The Ps-35 alongside the ever popular .......!
Spot the difference ?....you don't feel one !
Backtroller
10:33 AM
Land of Badgers
Here’s my Poleman 5100s. It started off as a really clean saw with low hours. It was pretty impressive stock, but Rich really woke it up. I haven’t had any of the carb issues.
Negatives: I guess it’s a little heavy compared to my my other 50cc, but it isn’t a deal breaker
It’s the center saw. Top is a 421 bottom is 7910 1CCD74E7-AB65-4F45-8FD2-3692452E0270.jpegCE02A642-6D4F-4FAA-8E8F-83B27FC7B3C3.jpeg I run a 20” 3/8 72 on it.
Simondo
3:33 PM
UK
It’s the center saw. Top is a 421 bottom is 7910 View attachment 136845View attachment 136846 I run a 20” 3/8 72 on it.
My 5105 is run with a 15" 1.3mm .325 set up....14 lb ready for fuel.
Common to run 50cc class with the 15 " set up over here.
Backtroller
10:33 AM
Land of Badgers
I ran a .325 and 3/8lp rim on my 421. 18” bars, but it was ported. I did not see much difference between the two.
Simondo
3:33 PM
UK
My employer had a ps420 a while ago I was fond of, I wonder why he sold it...
What kind of work did you put it to ? I guess you climb so did it go air born .
Simondo
3:33 PM
UK
I dont climb, however it did take a trip in the bucket truck on more than a couple occasions.
You find it started without much of a pull ?
Simondo
3:33 PM
UK
Bit of blue ...DCS 4301 . Same 2.0kw as the first Ps-420 was until it became the ps-420 sc and then gained .2 kw
The DCS became the EA 4300 and went to 2.2kw.
This 4301 has the Walbro WTE 6 carb rather than the Zama DM 23.
Simondo
3:33 PM
UK
No takers on the pop quiz yet ??
4:33 PM
Ps 420 sc ....Hex port. I feel they give the edge against the older single transfer port design that went before in the Dolmar/Makita range
There is little something in the exhaust port!
The only "Dolmar" saws equal and under 50cc in my lineup are my Sachs-Dolmar 105 & Sachs-Dolmar 108 - they are 40cc / 1.7kW.
This is my latest addition, a fairly minty Sachs-Dolmar 105.
She has some carb issues I need to track down.
Generally I don't use my small saws much, I tend to grab any one or multiple of my large ones no matter the job at hand.
Simondo
3:33 PM
UK
View attachment 136870 View attachment 136871
View attachment 136872 View attachment 136873
Hi Wilhelm. :)
I thought this thread might work nicely along side your 6xx 7xx thread as well as tempt you further to the smaller end.
Yea...that is a FUBAR cylinder from a customer who let the saw ingest a little something !!
FergusonTO35
11:33 AM
Boonesborough, KY
US had those plugged adjuster carbs ..not so good.
The good news is, when you order a replacement carb you find that the limiters don't actually limit anything. I can tune mine as rich or lean as I like with the limiters intact. I suspect this was Zama giving EPA the finger.
Love my 5105, everybody who has tried it loves it too. I have to admit, the Dolkita EA-5600 looks pretty sweet even though it has the wrong name on it.
