- 4:03 PM
- Dec 29, 2015
- Strong Island NY
Paint makes everything look better. [emoji12]Not only is the deflector great, the extra metal comes in handy too.
Here's a fix of the annoying 036/MS360 PTO side outlet issue on @MustangMike 360. Joe leaves enough metal on the sides for other use. So in this case, I could modify the existing deflector as well.
For any of you looking at all these somewhat fugly welds, the muffler bodies get embedded with carbon and grease and are not that easy to get a clean bead on.
View attachment 51177 View attachment 51179 View attachment 51180 View attachment 51181 View attachment 51182
Thanks Kevin.Welds look great Al !
If anyone is going to criticize those welds, they haven't tried to weld one. Thats a great job !!
Thanks Kevin.
I'm just trying to point out that they're not as easy to weld on as one may think.
It is possible, think this is a 2 or 3 ton unit.Wow, did that thing stamp out WWII parts? Awesome old machine.
What were you using before?I can do stainless, just a little more $$
Here is my little press, should speed things up a bit.
Thinking about making the medium, and large about .100" taller. Pretty much the same dimensions just a bit taller.
