Lone Wolf
3:48 AM
Nj
Then why would I want to go buy a bunch of em just because I got lucky and one worked? LOL
That may not be the way it works they come from different factories some good some bad and if you get a good one the rest may very well be all good also if from the same batch. I have a dozen 200T ones here that work great but it took a lot of trials and tribulations to find them. 4 batches to find them.
RI Chevy
3:48 AM
earth
Sad that quality control seems to be nil. Really hit or miss.
jon@camano
12:48 AM
Camano Isand, WA
Ya gits what ya pays for!!
Sometimes you can clear a speck of crud in the aftermarket carbs by removing the idle and high speed screws and spraying carb cleaner into the idle and high speed circuits. The aftermarket carbs seem a little more sensitive regarding small particles of crud. This has worked twice for me. Sometimes a new saw will run well initially then soon after not hold an idle. Its worth a try.
Jon
FergusonTO35
3:48 AM
Boonesborough, KY
Tried the 024 some more today. Same as last time, it starts up, cuts great, and idles for a little while before dying. I did find that, if you tip it forward while idling it will die real fast, like 3 seconds. Any ideas here?
PogoInTheWoods
3:48 AM
Ohio
Out o' gas?
I'm all suggested out, dude. Revisit all of em and you'll probably find the problem. Asking for more ideas is just pissin' up a rope unless you try the ones already provided. If you've tried em all, try em again. You're either missing something obvious or just not trying hard enough to find the problem.
Did you change anything since the last time you ran it?
FergusonTO35
3:48 AM
Boonesborough, KY
Didn't change anything from last time and filled up the gas before I tried it. I'm sure I am missing something totally obvious, will just have to back through it.
RI Chevy
3:48 AM
earth
Just asking here, Walbro WT194 carb or China carb?
Are you back at the 1 and 1 presets? The LA adjusted correctly?
2:48 AM
FergusonTO35
3:48 AM
Boonesborough, KY
Chicom Zama from Definitive Dave
Currently 1.75 on the low, 1.5 on the high
LA screw is adjusted a bit high but the chain doesn't turn when idling
When I get some time I'll go back through and recheck everything. If nothing else turns up, it could simply be that this saw and carb are just not going to get along and I need to get a real WT-194.
lehman live edge slab
Live Action
2:48 AM
Mn
If I’d dies fast when tipped forward I’d almost think low is to rich and puddling fuel in intake boot. When you tip forward it dumps extra gas in cylinder choking it out. 1.75 on low is quite aways out.
RI Chevy
3:48 AM
earth
Just mentioning this in passing in case someone wasn't aware.
The L and LA work in sync with each other. If you lower the L and increase the LA they should balance out. They are like peanut butter and jelly.
I personally would go back to the 1 and 1, and adjust the LA until you can get the saw ti start. Then run the saw. Fine tune the L and LA. Then tune WOT H needle.
My Chinese Zama runs and idles fine. Maybe not as good as a WT194, but good enough that you can use saw and work it, no problem.
DISCLAIMER:
not trying to insult anyone's intelligence. Just trying to help if anyone was unaware. [emoji481]
Someone feel free to step in and correct me if I am wrong.
PogoInTheWoods
3:48 AM
Ohio
Good points. If the original carb is still available (a WT22 maybe?) I'd be going back to that for starters.
And to break it back down to basics, there's either too much or not enough fuel at idle. The tipping forward clue could indeed indicate that the saw is loading up at idle and simply flooding itself out. Should be a pain to restart without pulling it over a LOT. Pull the plug and see if it's soaked with fuel. Turn the saw upside down and pull it over to see if fuel comes out the plug hole. If we have an overly rich condition due to the L screw adjustment, crank the idle adjust screw in for a stable, but high idle. Then adjust the L screw in each direction until the rpm's drop at each extreme. Find the middle ground between the two (usually the highest rpm) and call it close enough for the moment. Then adjust the idle screw back down for a normal idle (or at least until the chain stops). Rev and release a few times to see if it will settle into a reasonably normal idle without stalling. If it still stalls, it's still either not getting enough or too much fuel at idle. If the L adjust screw is somewhere around 1 to 1/2 turns out from seated, we're gonna rule out the L adjustment as the problem for the moment. We're also gonna check the plug again to see if it's soaked or dry. If it's soaked again, we're now going to investigate the metering situation of the carb itself. Odds are the metering lever is set way too high or there's debris at the seat of the inlet needle, either of which will allow too much fuel through the carb despite the general L adjustment we just roughed in.
If on the other hand if we have a dry (or normal) plug and the saw maybe even needs to be choked to restart after it dies, and given the fact that it seems to run and cut fine at normal operating rpm's, we're not going to go through all of the usual possibilities for fuel starvation like air leaks, fuel line issues, etc. We're going to look at the metering situation again after carefully inspecting the orientation of the diaphragms and gaskets to make sure they're assembled in the correct order..., just because. If the metering lever is too low, there won't be enough fuel drawn through the carb at idle even with the L screw turned out as far as you seem to have it set.
Depending on the knock-off carb you're using, the correct metering lever height could vary from the 'general' norm which is either level with the carb body or level with the floor of the metering chamber. There are exceptions in both cases, but the 'norm' for either carb body type should at least be close enough to allow the saw to run and idle. Both Walbro and Zama have a tool for setting the correct metering lever height if it needs to be below the 'norm' .
https://www.google.com/search?q=2+c...ome..69i57.10779j0j7&sourceid=chrome&ie=UTF-8
The easiest test for all of the above would be to simply change the carb and adjust it accordingly (provided you know it's clean, the diaphragms are cool, etc). If it is indeed a WT-22 like I seem to recall, it is a more than capable carb and certainly worth the time and cost of rebuilding. Unless it's filled with rust and corrosion it should come back around with a kit and some carb cleaner.
And speaking of diaphragms, it's also possible that the pump diaphragm in the current carb is too stiff to draw fuel at idle with the available impulse strength. There are different types of pump diaphragms made from different materials. The amber Teflon diaphragm is generally the thinnest and most flexible.
So....
Go fix this freekin' saw, dammit!!! I'm gettin' tired o' typin'!!!
LOL
FergusonTO35
3:48 AM
Boonesborough, KY
So....
LOL
Thanks so much for the detailed response. My wife and daughter are going to a birthday party tomorrow so mebbe I can spend some quality time on this!
