67L36Driver
- 1:52 AM
- Jan 18, 2016
- Missouri
I suppose it would depend on the condition of the brush cutter, the value you put on it, and how much use both the saw and the attachment will actually see. As I mentioned though, that looks like a very nice 08-S right there! But also bear in mind that the 08-S uses the same problematic SEM ignition as the 045 and the 056. I don't believe there is a Bosch version for that saw like there is for the 1115 series if you were of a mind to convert it in the event the SEM should fail. That stated, the TS350 chop saw version of the 08-S also uses the SEM and is often an overlooked source if you would ever happen to need one.
But, I was led to believe the chop saw ignition is rev limited. [emoji848]
Iffin it weren’t I have an 056 that would benefit greatly.[emoji6]
