PogoInTheWoods
- 2:54 PM
- Apr 23, 2016
- Ohio
I've got a picture of the procedure some place .The question is which hard drive????Yes. What Mike was saying is the flat rubber end of that intake boot has to be pulled through the hole toward the carburetor, then the bushing goes inside the hole and the carb mounts to the flat rubber.
If you wrap a piece of string around the flat rubber end of the boot, it will make pulling that through the small hole much easier. Loop the string around the flap and through the hole, then gently pull the string through guiding the flap around so it fits flat and flush. [emoji106]
They are getting harder and harder to get .Top Handle Pro saw. Lol. Good Used MS200Ts are going for $800 here. Lol
Check with @Lone Wolf. He is awesome with those saws. [emoji106]
M tron on the 201t and no M tron on the 200t would be the major change.So, what is the difference between the 200 and 201? Less smog controls on the former?
price .So, what is the difference between the 200 and 201? Less smog controls on the former?
the earlier 201 didn't... the m tronic is only recent on that saw.Hmm, didn't know the 201 had M-tronic. It's not advertised as it is for the 261.
