Simondo
4:00 PM
UK
Thanks
And the twin ring threw me off to.
But if it works I'll run it.
I have checked and found that the 115 (closed port) has the 2 ring windowed piston... 111 has the single ring open port cylinder and non windowed piston. Both are 44mm cylinders . Here are some pics of a 111 cylinder and piston for you to compare . All dimensions are imperial as i assume thats your preference. The 115 is not striped down for a side by side comparison .
old_sir_henry
5:00 PM
IMHO the number of piston rings doesn't matter. Dolmar has built one and two ringed pistons into the 115 and 110.
What makes a difference is windowed vs. non-windowed pistons, the former don't work well with open transfer ports, the latter
are better suited for open transfers.
However, I have had a 112 with open transfers and windowed pistons, many combinations work but maybe not as optimal as could be.
Simondo
4:00 PM
UK
One of a few concern I had with the 1 or 2 ring situation was where the ring ends came when putting a different piston design in a cylinder than was factory spec.... May or may not be a issue.
The dimensions of the piston and what it covers or doesn't cover within the stroke may just end up being to different along with the window V non window situation also a possible further negative.
At least the 111 and 115 have the same diameter and stroke so hopefully the dimensions i posted will give some assistance.
As a side note....Interestingly Dolmar are using a slab sided non windowed piston in some of the closed port saws now rather than the windowed sort.
10:00 AM
it's a CP head.
Aren't them new Dolmars using the slab side pistons bottom feed ports?
10:00 AM
So I measured my window piston and it was the same as you or measurements.
And feel free to use metric. We use it at work and that's what these saws a set up with.
Simondo
4:00 PM
UK
Good...You have options then along with NCfarmboys offer .
I do use imp and metric depending .... Miles ,feet and inches but the small stuff I tend to use mm only .
I think of the US as mostly a Imp user so I try to offer what folks may be comfortable with. :)
old_sir_henry
5:00 PM
Dolmar parts lists show the same piston for both 111 and 115, so they are interchangeable, regardless of the number
of piston rings.
10:00 AM
Think of it this way General Motors has been using metric bolts since the late 70s
We've gotten use to it.
Fishnuts2
10:00 AM
SE MN
