Dream
- 8:05 PM
- Aug 27, 2018
- Elberton, GA
Will this work to seal cases, or do I need Yamabond/threebond? View attachment 201135
Awwwww look at that little fella!Fuel system is crispest I have about ever seen, tank cleaning and new line and filter wasn't enough, going to have to rebuild the little Zama too. Otherwise in good shape.
Gas tank should just slid out, can be a pain sometimes. Had to take my kill switch off the last one I took out and move the wire out of the way.Got the 3400 apart today. Only bled once. Stupid rear av mount screw!
Looks pretty good in there. Cant really tell where the sealant gave out, but there is one spot that looks suspicious. Piston cleaned up nice with just a little wire brushing and scotch brite. Bearings all look good. Want to at least replace crank seals while I'm in this deep. Anyone got an aftermarket number for those?
Also seems the gas tank doesnt come out til the case is split, correct? Goes in the flywheel case half from the clutch side.View attachment 201130 View attachment 201131 View attachment 201132
Did you have any dull gray spots in the crankcase sealing area, if so I believe that would have been the leak area.Got the 3400 apart today. Only bled once. Stupid rear av mount screw!
All the little Poulans (and badge engineered ones) I‘ve had my hands on seem to suffer from brittle if not
already broken fuel lines. And the S25 has a very long line from tank in the rear bottom up and all the way
through the handle and finally reaching the carb. If tis line gets drained, the you'll have to pull the starter
quite a few times...
BTW interesting your's has a Zama, mine all seem to have Tillotson or Walbro.
Thanks for the catch, I messed up coping the wrong number. I posted Poulan part# by mistake. So sorry, I should have looked closer at my numbers.I looked the technical data sheet for the Ultra Grey and it's not recommended for parts in contact with gasoline.
Get some Permatex Motoseal.
For the seals, I think Steve meant National 253747. National is now Timken. Also SKF CR6119 or CR6120 which are about 0.001"smaller on the OD and go in much easier.
