T.Roller
- 7:22 PM
- May 11, 2016
- Southeast, TN
I'll see what I come up with. Thank you againVery cool.
FWIW, the smaller style vent valve like the ones in the 10 series caps (and similar to the common ones available) are definitely smaller valves, hence the 'creativity' caveat in using one.
You are correct it's a cp, it has the SP conversion for the better av I've been told.Nice saw - love the 125's.
Your saw appears to be a CP125 and not an SP125. Yours has the DSP lever and cylinder shroud and not the poppet decomp valve like the later SP125. Your saw also has the small kart type muffler that was std on the CP125. Would be interesting to see the lower handle brace mounting arrangement - the CP125 brace mounts onto the bottom of the oil tank using a different mount / bracket arrangement to the SP125, however I have seen CP125 saws that have been modified with the SP125 config.
It is a nice find - CP125 is not as common as the SP125.
Chris
It's the sleeved cylinder, I've already checked lolUnless I'm mistaken the CP has an iron liner .That's a good thing because if the need arises it can be over bored .With the SP and again unless I'm mistaken they are all chrome plated and if the plating goes bad you have two choices .You either replate it or make an iron liner .The later is a pain in the buttocks to do .I think I'm the only one who had that procedure on the internet .You should be able to pull the muffler and determine which you have by looking through the ex port if your curiosity gets the best of you .
I could be wrong but from what I've read, the C after 125 indicated a chrome bore.Unless I'm mistaken the CP has an iron liner .That's a good thing because if the need arises it can be over bored .With the SP and again unless I'm mistaken they are all chrome plated and if the plating goes bad you have two choices .You either replate it or make an iron liner .The later is a pain in the buttocks to do .I think I'm the only one who had that procedure on the internet .You should be able to pull the muffler and determine which you have by looking through the ex port if your curiosity gets the best of you .
I have read the same thing Al. My 895C carb also has a fixed high speed setting.I think the fixed jets were an early attempt to prevent people from tuning them lean .Then they cook the saw and then squawk about it .I try to replace them if I can find a substitute .
The only one I haven't is on old Poulan /Craftsman I used as a climbing saw before I had the Stihl 200T's .Now on that my buddy has a fixed jet on an 020T and believe it or not it runs pretty good .I was surprised .
I cut wood with my sp125c fixed jet at 3000 foot and sea level and it ran the same and never missed a beat. Maybe 5000 feet would be different but it just chugs along no matter where I cut with it.If I'm not mistaken the jets were sized for the elevation of where the saw was sold .If I get time and remember it I could look in my Tillotson book and see if it says anything about it .If that's true it might explain how my buddy's 020T runs so well .Then again if you land a saw sold in the Rocky mountains it might not do so well in northern Ohio with an elevation of around 800 feet or vice versa tuned for 5000 or above .I know from experience at those altitudes you have to crank in the high speed jet else they chug pretty hard .
