awol
- 10:04 AM
- Jan 4, 2016
- Cabool, MO.
The merits of using one have been and are beeing discussed in other threads, but here is a thread on how I have been able to use a stock crank, and turn it into a full circle.
I started this one by chucking on the pto end, and indicating to zero runout. A more accurate way would be to use a center in the headstock, and spin the crank between the centers.
After its centered, I run the tailstock up and put a little pressure on it. Then find the beginning point of cutting, zero the dial, and take light passes until we get contact on the throw side as seen here. This one only had to have .025 removed.
I used crank saver rings on the last one I did, but decided to make some from scratch for this one. I found a piece of old John Deere hydraulic cylinder tube, bored it for an easy slip fit of the crank, then turned down and polished the od. The rings are .025 thick, so with the loose slip fit the assembly will be a bit larger in diameter. Here are the rings getting parted off.
And the old crank with new rings slipped onto it.
And the crank fitted inside its case, just to see how it would look!
