- 4:49 PM
- Jan 8, 2016
- Mandal, Norway
Cranks... they used 4 different cranks.
Picture show crank 503 53 67 02 to the left and crank 503 53 67 04 to the right, 12 mm vs 13 mm conrod bearing (when we study the cut in the con rod pin to the axel it's easy to see that the 04 has bigger conrod bearing)
503 53 67 01
12 mm conrod bearing
42, s/n 0450748 ie year 90 week 45
242 SE, s/n 0130392, ie year 90 week 13
242 SG, s/n 0130001, ie year 90 week 13
503 53 67 02
42, s/n 4110291, ie year 94 week 11
242 XP, s/n 4130001, ie year 94 week 13
242 XPG, s/n 4110001, ie year 94 week 11
503 53 67 03
This crank was solely used as substitute crank for the 01 crank.
503 53 67 04
This crank took over after the 02 crank, and it should only be used in crankcases after those s/n's:
42, s/n 0450748, ie year 90 week 45
A 246 crank is far as I know crank 503 53 67 04 since 246 arrived after 1994 week 13 far as I know about.
Hi Barry.I know, this is an old thread but I have a couple of questions on this. The note on the 503 53 67 04 says that this should only be used in crankcases that originally had a 13mm crank bearing in it (after 503 53 67 02) if I'm reading it correctly. I was wondering why that was? For all of them I'm assuming the stroke is the same and also assuming the shaft diameter is the same. Is it that the added material to support the larger bearing will rub on the inside of the area it rotates in?
Also, can the number etched into the counterweight be used to know which of these crankshafts are which? Can someone provide a translation?
Thanx
the one who miss the s/n, the crank is most of the times inside a few weeks old, BarryThanks Tor, that explains the what and why. Now I need to know the how. I have several cases I tore down before I knew there was a difference. One of the cases has no serial number tag so I don't know the year of manufacture. Short of getting out the vernier calipers, is there a way to know which case style this is?
When it goes to how to sort them cases, the old 01 case has 28.5mm distance wall to wall.
thats right Barry, inside edge of the crankcase bearing wells. 29mm sounds correct for me."wall to wall" - is the measured from the inside edge of the crankshaft bearing wells? Quick measurements here seem to support that.
So from what you said earlier, the 02 crankcase has a distance measurement of 29 mm?
your 5034592-02 crank was produced in 1991 week 25, while your 5034592-04 was produced in 1995 week 12.I measured the two crankshafts I have and both measured 27.2 mm with a vernier so I'm assuming they are 02 or o4 models. I also measured the conrod bearing pin diameter and one appears to be 12mm and one is 13mm. So I assume what I have is an 02 and an 04 crankshaft.
Now the question. On the supposed 02 crankshaft, it is etched with "5034592-02 SWEDEN-B 91 25" on three separate lines. The supposed 04 crankshaft is etched "5034592-04 SWEDEN-C 95 12". If the last line is the date code, can't we use that to know which crankshaft type these are given your notes above about the cut-in dates? At least for these two, that would seem to be the case.
And yes, my 02 and 04 cranks is 27.2mm counterweight distance.
hi Joe,
Il only speak as i have found Joe .
the hard part is to nail down a good 242 top end.Thanks guys.
Josh has been experiencing a little 242 envy lately and I have found a couple of 42 Specials on eBay for descent prices. Maybe a good candidate to swap a 242 top end in and enjoy!
Welcome to the site and great score. @Tor R will be your best bet for help.ATTN: Tor R & others!
As of today I have a new to me 242XP. Super clean and COOL little saw! As we know seals do not last forever and since I do not know the history of this fine saw I thought I should address items that are saw killers ,like leaking seals, before using it.
Can anyone help with locating PTO seals? Suggestions or guidance will be appreciated? Serial number is: 1180279
welcome to OPEATTN: Tor R & others!
