GlocknStihl
Derelict OPE Member
- 11:31 PM
- Aug 12, 2018
- At God's feet
I made the other thread about my $80 purchase and the tear down. Now its finally on to reassemblly.
The case has came fairly clean, still need to do a little toothbrush work.
The tank came a lot cleaner than I thought it would too.
Where it was ran with the muffler loose, it melted the top cover, and caused the Air Guide Shroud to warp. It also boogered the threads up a little. Should I run a bolt on them and see if they clean up, or should I run a tap through it ? Also wondered if it would be better to tap them a size larger?
My new parts came in, I already have the new oem top cover and a new oem muffler. I had ordered a new piston kit, new fuel solenoid (updated), new carb kit, handle moulding, stop buffer, 7 & 8 rims, new seals, HD2 filter, fuel filter, and the double bump spikes.
I was thinking of advancing the timing a little. Anyone have experience with that, or know how much to take off the molded in key ?
I'm planning to keep it 325, but havent decided which size or brand bar to try on it. I've always used Stihl bars, but would Tsumura be a good choice?
