- 7:27 PM
- Dec 28, 2015
- Central Ohio
Yep low fuel alert, check that list of features, we are taking pre-orders now
Bluetooth?We are developing a new tach app to be used with google glass for the upscale urban arborist.
While you cut with your freshly polished, sharpened and fueled chainsaw the app will constantly update your critical cutting information through our patented interface and display the relevant stats via heads-up display on your google glass.
Can relay all of the following in near-real time:
max RPMs
average RPMS
HP
BHP
width of kerf
width of piece being cut (replaces mango markers, etc.)
pressure being applied by user as measured through the AV buffers to advise when sharpening of chain is required
Current chain speed
Average chain speed
Clutch slippage alert
Aftermarket clutch alert
Air filter load alert
THrown chain alert
Low fuel alert
Ethanol level alert
Low bar oil alert
“Your brother just straight gassed your saw” alert
Current bar temperature
Average bar temperature
PPE reminder upon start up
“You flooded it” alert
Plug color readings
Flip bar reminder
Chain on backwards alert
Cheap 2 cycle mix alert
Wrong ratio mix alert
That’s used motor oil alarm
Cant hardness
Total BTU cut
Hottie proximity alert
Top cover gloss level
$2675.00 with free shipping, does not include saw, google glass, fuel, oil, bar, chain, sensor array or hottie.
No but if you place your cylinder at the end of the rainbow, turn on blue tooth, it will turn into a unicorn. Your WelcomeWill it tell me when my cylinder is maxed out?
Will this include the new in the case metal flake detector?You can also set an alert to tell you when to pull the jug and check the wash on your piston, we are working hard with our partners to integrate a compression chamber temp monitoring system as well as a dynamic compression monitor/regulator feature and real time timing changes.
Ahhh yes, the BOD stare.....Does it have an indicator as well when to pull up stare into the wild blue yonder and listen to
the metal shavings grind the inside of your saw while piss reving??
max RPMs
average RPMS
HP
BHP
width of kerf
Current chain speed
Average chain speed
THrown chain alert
Low fuel alert
Ethanol level alert
Low bar oil alert
Plug color readings
Flip bar reminder
Cant hardness
Total BTU cut
