Fruecrue
certified hand catcher
- 5:44 AM
- Jan 4, 2017
- Alden NY
Gives a guy a lot to think about. My brain wants to trend data. I’m always looking for a relationship of bore to stroke vs. what timing or other characteristics make a certain motor shine. Induction stroke seems relative here, as does blowdown.The 'induction stroke' for a two-stroke is from transfer closing to TDC. When you raise the transfer height, you reduce the induction stroke. (you can get the same time/area by widening the transfers without reducing the induction stroke)
It would be interesting to see what a stock 7900 performs like when the crankcase is machined out to give an extra .30" of clearance. The added crankcase volume will reduce the crankcase compression and broadened the powerband.
I’m still trying to fully understand what makes this saw run best with more blowdown than others.
Not trying to be picky, but that added crankcase volume comes with an added mm of stroke, so saw isn’t exactly stock anymore. I think I’m picking up what you’re putting down though. I’ve been told that tight case helps to make the 7900 what it is.
