Stroking a Dolmar 7900
RI Chevy
9:59 PM
earth
Good thing you were wearing your PPE clothing. [emoji16][emoji6]
Fruecrue
certified hand catcher
9:59 PM
Alden NY
Looks good Dave!
Got any more changes to make or things to try? Or just going to run it?
I think I’m done with the saw however I may advance and retard the timing a couple degrees and time the cuts to be sure.
Trying to match the chain and drive set up to suit what I expect to see in Tennessee is top of the list right now.
mettee
6:59 PM
Arizona
I assuming you ran an 8 pin with a chain that had a little more bite, but I'd be curious to see that if not.
Stroker and all, the torque is there to take advantage of.
mettee
6:59 PM
Arizona
Was just curious is all, not questioning his chains. I haven't seen anything posted about it.
More curious about taking advantage of the torque since he was slowing down the cut with pressure
Deets066
AKA Deetsey
9:59 PM
Says it was a 9
Fruecrue
9:59 PM
Alden NY
Different chain, more aggressive for sure.
Same tune, I strapped a tach to her.
Tune wanders a bit. First piss revs after warming up a bit at around 14k.
Piss rev between cuts when hot and it’ll wander to 17K.
Seems nice in the cut though, I wonder if the divider in the RWJ is playing games at no load full throttle.
Either way, it’s holding 11- 12k in the cut depending on pressure.
