usmcbuckwild
Buck
- 8:55 AM
- Dec 24, 2017
- NW CT
Too many cervasas. [emoji16]
Not enough. I was HURTIN
No upcuts? WtfSwapped to an HD-12, found some gains.
2.4
2.44
2.53
2.37
2.22
Thanks Clint.No upcuts? Wtf
Looks pretty strong man, definitely a top contender. Still using factory boot?
How far out on the screws are ya? Just curious.RWJ gained over the HD12.
Didn’t run the air filter, would have taken some modification to make it fit.
Perhaps I should run the HD-12 again without a filter for comparison.
Wood is also getting slightly larger.
I wrote down the cut times but left them in the garage.
Average was 2.36, didn’t time the *s-wordty upcut, that was just for Clint.
No idea.How far out on the screws are ya? Just curious.
I believe the throttle arm hits the plastic bulkhead between the carb box and cylinder at wfo. On some 372's I've needed to trim some sheath to get enough cable so it would idleNo idea.
I did have to take them way out.
I thought for a minute there was an air leak as I couldn’t get it to idle under 4K.
I need to check the throttle plate.
This was a brand new RWJ-4.
It was idling near 5K and piss revving to 16k out of the box with both limited screws at max.
I grabbed the spline adjustment driver and just kept spinning until the chain stopped at idle and max piss rev was 13,800.
