Stroking a Dolmar 7900
Fruecrue
certified hand catcher
7:18 PM
Alden NY
Had a couple minutes so I threw the wheel on her.
Amazing what a millimeter of stroke and a spacer under he jug can do.
Right now I’m reading 102.5 ex., 125 trans., 76 intake.
Compression 175 psig.
Fruecrue
7:18 PM
Alden NY
Con rod length may play a role there as well.
Dolmar stock rod is 65mm center to center.
Waiting on a slow member to let me know solo con rod length, as I was a slacker and never measured mine before I put it in the saw.
Fruecrue
7:18 PM
Alden NY
Also....
Pulled the flywheel and re-mounted 30 degrees andvanced.
Will be fitting an unlimited husky coil when I have the time.
Possibly may go to a friends house and lay down a dozen or so dead ash trees this weekend, it would be nice to have it back together before then.
1:18 AM
You did not measure Your rod before using it?!
Blasphemy. :rolleyes:
mettee
4:18 PM
Arizona
Do you think you will bring the jug down? A small base gasket would really fubar those numbers wouldnt it.
Do you know measured squish?
I want to see what the timing bump did :)
Fruecrue
7:18 PM
Alden NY
1)Unsure of what I’ll decide to do yet. Still looking at other piston options, though I don’t think I’ll go that route. Right now I’m leaning toward swapping jugs and slugs from my 7910 to this saw, cutting the band and leaving the base to run with a standard gasket. Should net me enough compression to raise the exhaust port where I want it.
What’s holding me back is Idea of finding a way to bump compression, have exhaust in the mid 90s and 28 degrees blowdown without touching the uppers. Offset pop up cut on a taller piston may allow all of that. If it comes with wider skirts and ports, that’s very appealing.
2)Squish right now is .023”
3)Me too.
mettee
4:18 PM
Arizona
How thick is that spacer again, like 40?
Deets066
AKA Deetsey
7:18 PM
You could cut the base about .030, then time the jug again and decide how much you want to cut a pop up or if the trans are where you want just cut the chamber
Fruecrue
7:18 PM
Alden NY
If I cut the chamber now my squish would suffer.
The goal would be to leave the spacer and the band. Find a suitable piston to cut and raise exhaust.
Deets066
AKA Deetsey
7:18 PM
If you dropped the jug.030 you would get your intake and trans closer to where they need to be. If you cut the piston your trans would stay the same as they are now.
Fruecrue
7:18 PM
Alden NY
Light bulb.
Sorry, I’m slow.
That would still leave me a bit short on compression me thinks.
