Eagle1899
- 6:09 AM
- Oct 31, 2017
- Central Minnesota
I am in the process of working on a few saws (262XP and a 372XP Chusky kit saw). When I get those done a mechanical restoration is due on my Stihl S10. After looking around a bit... parts are scarce.
I was hoping some one can help me with some part numbers and sources.
Mainly:
Crank seals and bearings
Case gasket
Cylinder base gasket
Ignition points
Ring size thickness for possible Caber match up (not sure if it is a 44mm or 47mm)
Thanks in advance!!!
Trever
Mainly:
Case gasket
Ignition points
Trever
