jackjcc
- 1:42 PM
- Apr 22, 2016
- Minnesota
Up for sale is an 026 Pro, I assume it's an earlier model. This saw sat for quite a while somewhere, I purchased on eBay for $75 shipped and put $150 in parts. It has new A/V, boot, carb kit, fuel, oil, crank seals, drum, sprocket and filter. I might be missing something on there. The hearings were tight when I had the seals off so I did not split the case. Has .325 sprocket on it and can include the bar and Stihl chain free if you want it. Runs, oils, and cuts like it should. Pretty good overall condition.
The bad: I'm fairly certain it sat on concrete as the bottom of the tank has pitting and a small chunk missing from the front near the handle. I didn't think to take any pics of the inside when I had it apart but it only had some paint chips missing. There is some paint bubbling and the tank vent leaks a little.
Blows 180psi...I feel that might be a tad high but it has a real good pop when turning it over. The muffler cover has a few additional holes drilled in it to give it a mild muff mod. I have 2 tanks through it the last year and most of that was getting it tuned after rebuild. The ms241cm became my go to especially after it was ported.
If you don't like the price make an offer.
