bikemike
- 1:52 PM
- Feb 4, 2016
- Cottage grove mn
Not a derail. Just a example this is from a galaxy s5 this weekend
My edits were the pause button on my phone. Took the vids that I did get. Post them on youtube then copy link to here. I don't know computers at all. If someone tells me I'm dumb or stupid with a computer, I smile and agreeMike - what program do you use for editing? I'll be moving the videos to my laptop. And thanks, I like the little hot saws.
Do the same runs after you have more fuel through them. They both sound a bit tight or newVideo of saw #1 and #2 in dry 14" cedar, brand new bars and chains.
Forgot to mention - both saws were warmed up prior, so lack of throttle response on #1 isn't very noticeable.
Did you get a chance to run the 200 and 193 together?I was able to run the modified 193T today with the shaved piston skirt and 6 degrees of added intake duration.
It starts easily cold or warm, idle is stable, and there is no spitback to the air cleaner. It sounded like it was hitting a rev limiter at 13,300 so I set it at 13,100, made some cuts, and I'm impressed. Throttle response is immediate and it pulls hard (for a 30cc). Not sure it's worth the effort, but as soon as I can run it against a 200T I'll report back.
Have you been in a 193 or 194 yet? Pics? What do they need porting wise?There's room in a 192t to port it a bit. Not a lot on the intake side, quite a lot on the exhaust.
193t is unknown to me.
Some castor oil and long hot cuts would help take care if the decomp trough. It would be interesting to see if JB Weld would hold up in it, but that's pushing the limit big time. That could end up being a slow release of polishing compound.
110 stock exhaust? Not bad really.
