Anyone here able to weld it and tap new threads?
Looks nice just like you said yes.Rest of the cyl look pretty good? Sorry about the packing job, it was supposed to go in an envelope
Thread insert or weld and tap?Shaun Carr did two for me. One 441, one 044. Both were professionally done and run great.
It came to me this way. I suppose someone stripped it and tried to Heli coil it and failed.Wolfie, how did the plug threads get messed up? Any idea? I've never had any problems with the plug threads in my 046 Mag. Just curious.
I've never seen it done that way to risky if you ask me but you should be able to tap and hely coil it and be good to go.Anyone here able to weld it and tap new threads?
No local guy wanted to try it, so it went to Scarr52. I’ll be sending more work his way in the future.I've never seen it done that way to risky if you ask me but you should be able to tap and hely coil it and be good to go.
The inserts work fine if done correctly, have 26 saws out there running with inserts in them, been 12 years for some, no leaks or coming loose.
I cant find him on here?I've only seen it on 441's, not 461's. Shaun can fix it up right
PM sent.
