Carls421
OPE Member
- 8:52 AM
- Dec 31, 2019
- Norwich, England
Hi again,
So on the bench I have a BR550 backpack blower, it’s had a few issues which I’ve fixed but this one particular thing I’m struggling with and could do with a bit of advice...
I had to replace the primer bulb as it was split, i know I've put the pipes back on the right way but it’s not filling the bulb? The tank did have a slight hole in it but I’ve fixed that, but my question is about the fuel tank vent, which direction should it vent? Without wanting to sound daft, am i right in saying that the “vent” should suck air in and not blow out? I block all holes up and put slight pressure into the tank but air blows out of the vent? It should pressurise that tank when you pump the bulb right?
