Allen Miller
- 8:24 AM
- Apr 8, 2018
- Muncie INDIANA
YesAre you talking about a piston with 2 height changes?
Sent from my SM-S907VL using Tapatalk
I was trying to 100/80/120 all the reading I've done seems like there all over the place. Not trying to make a lot more rpm just a lot more torque . I have gotten 102/84/117 and .018 Squish. Seems like you have experience here what # do you suggest. ThanksThe epoxy works great! You don’t want to permanently cut a notch in your piston to make port timing adjustments, it is ok to test a change without grinding but it will effect your squish and create a bad burn. What are you trying it get out of this, you may be better off starting over? What didn’t you like about the original numbers?
Raise the exhaust to 98 and try that. You might surprise yourselfI was trying to 100/80/120 all the reading I've done seems like there all over the place. Not trying to make a lot more rpm just a lot more torque . I have gotten 102/84/117 and .018 Squish. Seems like you have experience here what # do you suggest.
Ok I'll try that. Out of these 3 carburetor which is best performance 1st walbro wj 76b , 2nd wj 35A 3rd wj 69 with .074 jet . Been using wj 69 I installed the. 074 jet but don't really care for limiter caps. Also any good carb modsWhen I cut 40 out of the squish band I got 100/132-135/87 I wanted torque as well, I epoxy the intake to 80-81 and raised the transfers to 127-125, I might go back in and play with it some more, raise the transfers, but I need more trigger time on it. I ended up with 200psi and it sill starts easy, with timing advanced.
Ive ran 103 - 93 on exhaustWhat numbers do you like to run these saws at?
18-20 blowdown
Intake:
78 - 84
Exhaust doesn’t seem to be the most important number on the 1122’s .......... blowdown is.Obviously you've done a lot of work with these saws.
Can you summarize your experience with different port work you tried.
What worked well and what didn't?
I believe the crown starts to erode. At least that’s what I’ve been told.I heard the rule was .100 minimum.
What happens if you break the rule?
I done that . I cut the ends off when I got saw a couple years ago. I was wondering if there was any difference between carburetor. Just look at them only change on outside was limited caps. I did check the two older ones had the larger jet .Always remove the limiters on the caps. If your saw "4 strokes" out of the cut, you are getting enough fuel.
Cant go wrong with 20 degrees of blowdown, I’ve ran 18, and I’ve ran 22 depending on muffler configuration and intended use
A restricted exhaust will need more BDI appreciate you taking the time to share, I know that's some hard earned knowledge.
Can you expand more on the blowdown.
What situations would you want to shorten or lengthen?
Think time/area as well as what else is happening if you decide to increase blowdown ?
I haven’t seen 17 bd any better than 18, even running no mufflerSo you open up the stock muffler to get away with a shorter blowdown.
What keeps you from opening the muffler further and going to 16?
Maybe too much fuel out of the exhaust?
Lost case compression?
What situation did you decide to run 22?
