brshephard
Stihl saws, Husky women
Until the piston or band get some carbon on them
Exactly. Not a very practical number.
Thanks. Exactly what we were trying to say.FWIW I tested a high compression 660 jug similar to the OP yesterday.
AM at 102/122/77. Blew 245 dry.
Torque was awesome. RPMs were kind low.
The problem, though, was all the heat it made. It would lean out like a half turn in a 10 second cut.
Also dieseled hard when shutoff.
Basically, way too hard to keep the carb dialed and hard starting. Not good for a work saw.
Most guys have gotten 200 psi gasketless with a Cross 660 jug. Did you do other mods to see 245?
Exhaust110 Intake 85 transfer port 115 that wear cylinder was at the time of post. Just started working on again .I'm looking forward to seeing how this turns out.
When you get ready to check your port timing, Mastermind has a good video on setting a wheel up.
Numbers are read as: Exhaust/Transfers/Intake
Exhaust is read when the exhaust opens in degrees after top dead center (TDC)
Transfers are read when the upper transfers open in degrees after TDC
Intake is read when the intake port closes in degrees after TDC
You want to end up somewhere around 100/120/80
Here are a couple good threads:
http://opeforum.com/threads/mastermind-meets-the-ms660.244/
https://www.arboristsite.com/community/threads/066-ms-660-port-s-please-share-your-stock-s.263751/
Special thanks to Shaun for that measurement. Here is a chart specific to this saw that shows the bore distance across various timing changes.
It works as follows:
1. Find your current port timing number.
2. Follow the row across until you find the timing number you want.
3. The corresponding value is the distance between the two in ten thousands of an inch.
4. A positive value means you would need to grind material. Negative would require decking or epoxy.
Example: Suppose I dropped the exhaust to 105 and I want to go to 90 to do sick piss revs. Go to the 105 row, then look at the 90 column. I would have to grind up .1961" (highlighted yellow).
You can also use the tables to predict where timing will end up when decking. Suppose my transfers are at 115 and I knock .050 off the base. Go to 115 and scan across the row for .050. 120 is at .0528 so I'll end up around 119.5.
Let me know if it works for you guys
Exhaust
Transfers
Intake
My bad. I missed the pop up part
I think his intake # may be right.
Nope not at all. By reading your post i realized I'd forgotten about the pop up.I hope I didn't come across as trying to give you a hard time. You're a heck of a lot more knowledgeable than me.
What do you think of that popup? I measured .133 crown to land on a Cross piston, that leaves around .070 after milling.
I heard the rule was .100 minimum.
What happens if you break the rule?
I think so too.
I'm going to machine some the Dome off the piston but first I was going to work on getting then intake the exhaust and the port timing right just got a new meteor piston so as soon as I get it where I want it I'm going to make a new piston for it. I only want 190 to 200 max. Had to start somewhere. I don't use this saw more less give me something to play with.If you don’t want the compression why not take some material off of your pop up, then you can easily dial in your compression
Just as a reference, I had an oem jug that I had 40 thousands taken out of the band, netted 100ex duration and 200psi and had to epoxy the intake to get it back up to 80I'm going to machine some the Dome off the piston but first I was going to work on getting then intake the exhaust and the port timing right just got a new meteor piston so as soon as I get it where I want it I'm going to make a new piston for it. I only want 190 to 200 max. Had to start somewhere. I don't use this saw more less give me something to play with.
Sent from my SM-S907VL using Tapatalk
How did epoxy work out. .030 change everything. Raising jug up .030 makes E100 Int82 but transfer I'm going to grind them . Has anybody ever tried a double step pistonJust as a reference, I had an oem jug that I had 40 thousands taken out of the band, netted 100ex duration and 200psi and had to epoxy the intake to get it back up to 80
