- 6:49 AM
- Dec 29, 2015
- Strong Island NY
Try not to stab yourself in the hand pushing it all back together. I ended up using the channel lock pliers to hold it together so I could drive the roll pin back in View attachment 188820
I’m still trying to figure out why the “scoop” section being deeper of larger does anything. The amount a piston can pump in a bore has to be the swept volume, regardless of initial or ending volume. So with a deeper scoop, you just get more beginning and more end volume, but the change (what gets pumped out) should be the same. Unless the edges are narrower and allow more fill and dump time, that I’m not sure on.
I won’t help with a stock p&c?
Or do u think he will gain power with the 044 carb and boot and only a muff mod?
Only did on ported ones. Not sure if it’s worth the effort on a stock jug. 2 factory jugs exist, I can’t recall for sure, but I think it was the “Stihl” branded jug and not the Mahle that had the bigger transfers.
Changing to the 1128 HD carb requires the boot/surround and drilling a spot for an 1128 impulse line. Also, the choke rod needs to be swapped between carbs.
They run well. One I did clearly beat one of my 036. The muffler on the 361 purely sucks balls.
Chit, I wanna know who's porting it! Lol
