Mark71gtx
- 2:22 AM
- Jan 14, 2016
- Fuquay Varina, NC
I was brought a 200T that "just don't run right." I ripped it apart and did a pressure/vac test. It passed. I took a look inside the tank and saw the fuel line was cracked just below where it connects to the tank. Installed new fuel line and put saw together. Fire it up, and all is well. Take it out for a field test and to tune it. China carb, so no "stops" on carb. Start at 1 and 1. Keep messing with it and it will never tune properly. It actually seems to run best with the "L" turned all the way closed! I am assuming this carb is junk... What should I look to replace it with? Thanks!
