RedFir Down
The first question I have is about the tank vent. The saw had a make shift vent when I got it so I looked up the IPL for the saw and order what it called for. Needless to say it is wrong. What style of vent do I actually need?
Next is the on/off/choke lever. With the lever all the down it does not engage the high idle and when you move it one click up it binds and will not move unless you hold the throttle wide open. The lever has quite a bit of play in the tank housing. So I'm not sure if its the lever, spring or a warn part under the trigger cover. What are your thoughts?
Also I ordered a OEM dual port cover for the muffler and noticed a gap on the bottom between the muffler and the cover. What is going on here?
Thanks for the help.
I'll post pictures in a minute.
