MS290man
045 carb, freshly rebuilt with all new gaskets, screen, diaphragm, etc.. I completely disassembled the card, including the high and low needles, and sprayed carb cleaner through the adjustment holes so that I could see that both the high-speed and low-speed circuits appear to be clear. The saw will start and idle but I can't get rid of the bog in the transition between low and high; The saw hesitates then comes back. I did adjust the needle lever because the carburetor was flooding out. Adjusting the lever fixed that but I'm wondering if I adjusted it too far and it's starving for gas?
