gd1996
Active OPE Member
- 12:05 PM
- Sep 11, 2017
- Latrobe, PA
Have random o34 036 parts, no plans to build any soon and over loaded with parts.
034/036 crankcase, good bearings, crank, rod bearing etc. Fairly clean too. Doesn't have a flywheel on it, but have a couple also, will include 1, 5mm recoil holes, $50
034 open port cylinder, couple broken fins but good bore 35
036 48mm cylinders, good bores/plating 50
036/360 with decomp hole SOLD
Another 034 crankcase, bad rod bearing but will include a good crank/rod, 40 has a flywheel, tank is there but will remove as it's broke where control shaft attaches by the vent
Crankshaft with good rod bearing and has crank bearings 25
Or make an offer on any of it or will sell as a lot.
Will trade for 046 460 064 066 and ms660 parts also... have a ton more of parts also
