Gary Courtney
- 3:13 PM
- Jan 5, 2016
- Froglevel
Installed an a/m carb on saw and it cranked up and adjusted h/l jets . will idle all day at 3200. the idle screw all the way out does not affect whatsoever. cut with saw and cutas it should but will not idle down.
did a vac/pressure test which passed. Also if i tip saw down on muffler front the saw will slow down until it dies. has new fuel and filter. tank is venting properly. sprayed carb cleaner around boot and impulse with no change in rpm's . any advice
