Wonkydonkey
Plastic member
- 11:38 AM
- May 14, 2017
- Sussex, UK.
Thanks for the update, I’m liking to the bb 440's
Well, she is running, but not before scaring me!
First, it took 12 pulls to get her to kick, seemed like a lot. Then she seemed to be running fine, did 5 nice cuts, then she dies.
I check the plug connection, then I'm worried that the flywheel spun, so I prime it and she kicks. Even though I had a DDave carb on it, based on past problems I change the carb … no help.
Prime it again, she kicks. So I change the fuel filter and we are good to go!
Saw feels good, but I've been running the 066 so much lately I may be expecting too much from her! We will let her break in a bit and see how she does, but she does not run bad! Very responsive to the throttle.
Gotta run, my Step Son's Birthday today!
I got a few of the cheapest BB660 kits I could find to practice porting on, and I quickly noticed a huge gap under the piston if pushed to the top of the cylinder. I assumed the squish band would have to be huge to prevent free porting, so it's made me wonder. Could I rough up the bottom edge of the exhaust port and add JB weld and shape it to raise the bottom, or would heat and or heat expansion burn it out or knock it loose?
Good excuse to run nitro. What about welding a popup disk on? I guess that'd be kinda heavy.Just stack up a few base gaskets, problem solved!!!!
Good job I like those numbers to she should run very strongI did the porting on my outdoor workbench (I C clamp the cylinder to my trailer). It was actually nice (very briefly) in the early afternoon. Colder this morning, then got windy and colder again in the late afternoon.
This cylinder needed lots of work. My work is not as pretty as some, but it will run a lot better than it was! Did not want to move the exhaust much, but was hard to fix the problems and not move it a bit. The intake came out right about where I wanted it.
Final #s are Ex 95, Tr 118 and In 78. I think those #s should be good. Increasing the width of the exhaust, moving the upper transfers toward the intake (and the small bridge ports), and lowering the intake should make a nice difference in how this thing runs over how it would have run unmolested. Maybe tomorrow we will get to fire it up!
Nice.Ran the saw again today and it seems all it good now … rewarding to finally get it right when you have encountered numerous problems!
I sharpened the chain and she cut real well. Does not have the torque the 066 has, but I guess if it did it would mean I did a piss poor job on the 066!
I really like that she is well mannered. Idles smooth, and if it is warm, even if I let it sit for a good while, I can just press the decomp, put her on run, and she starts right up. I really like that in a saw cause I often shut it down to mover a few rounds with the peavey, then re start it.
The heavier piston seems to produce a few more vibes at idle, but when you pull the trigger it seems to smooth right out, so I'm good with it.
