kpkustoms
Figured out might not b the greatest way to put it but I've def got a lot of thought into it. I think the hardest part will b finding a duel direction motor that will accept a wheel
If time is money you'll have double a used silvey in it.
You could be on to something, have you started any fabrication on it yet. I would love to see. If so, I could be interested in one.Your def right no doubt but time isn't wasted if I built something useful with my own hands
That's actually the easiest thing to overcome. Most motors are easily reversedI think the hardest part will b finding a duel direction motor
I bet you will have learned how to square file by the time your done building it.
I'm just learning myself. Even an okay square filed chain cuts as good as a good round filed chain. Buy a couple styles of files and give it a try. Worst case is you mess them but and turn them into round filed chain.
Homelite has a awesome chain vise he sells, have you seen it?
DPDT switches are your friendThat's a good point just reverse the polarity
I haven't used it yet but I will in the very near future. I bought a loop of square at the NY GTG and ran that a while. I took a shot at touching it up then went out and cut more with it (cut good). It was working well until I cut a round that was hollow and half full of mud. F'in toasted it! I was going to put your chain on and cut more this week and see how it does. I'll try to get that other chain back into shape but I know it took it rough. FML I should have used a rototiller to cut that log.How did you like that chain I gave you in NY Wade?
I think I'm gonna change my angles a bit...
