I have an opinion question that I may as well ask in this thread. I apologize if this is a hijack, but it may help the OP have his question answered.
I'm currently working on a Stihl 361. 59cc and a 47mm bore. First one I've ever touched.
I have 2 jugs on my bench. One a "Stihl" branded jug (may be Gilardoni) and a Mahle.
The Mahle has smaller tunnels and smaller transfers. The Stihl are larger. I've been told the Stihl jug "is better" because of this-size matters.
I still haven't timed the jugs, that's happening tonight. The lower ring pin is on the flywheel side of the exhaust- so I will need to lose the bottom ring, not widen the exhaust port, or relieve one side only slightly.
I'd like a 104* exhaust roof and a 76* intake on this saw. My thoughts are for around 20* of BD for the primaries and 22* for the secondaries. So 104/124P/126S/76.
If I cut the band, I will likely need to raise the transfers up. If I cut a popup piston, I will need to raise them less, but still will need to raise them a bit.
If I use the smaller Stihl Jug, I should be able to run less BD because A) there should be greater pressure in the tunnels and B) they will need more time to fill/purge the column of swept volume.
So which jug would you use and why?
If I cut the chamber, I can raise the smaller transfers and they won't be as large as the bigger ones will be. If I cut a popup, the bigger transfers will only be raised a bit, so I can maintain the factory uppers with less grinding and the factory roof.
Even though I've been told then Stihl Jug is "better", I'm thinking that the smaller and tighter transfers might actually make more rpm and power.
Opinions?
