I said "choke" dammitKinda wonderin if it was a joke
If it runs fine once fired up, then it’s not likely the impulseits using wj118 carb for husky 390 xp with choke assbly removed. if i prime it, it starts and runs great. once i shut it off it won restart without being primed again. im wondering if i should just change the pulse line and fuel line.
Just keep it runnin'its using wj118 carb for husky 390 xp with choke assbly removed. if i prime it, it starts and runs great. once i shut it off it won restart without being primed again. im wondering if i should just change the pulse line and fuel line.
Could give it a lil' squirt right after you shut it down. That would prime it for next timeThank you, I think your right. I opened the low side and raised the idle some more I can now get it to start but it takes two to three pulls which isn't great for competition but it will get there.
I would definitely check your fuel line for a small hole and throw a kit in itits using wj118 carb for husky 390 xp with choke assbly removed. if i prime it, it starts and runs great. once i shut it off it won restart without being primed again. im wondering if i should just change the pulse line and fuel line.
Kinda sounds like your needle isn't seating all the way and emptying your bowl.its using wj118 carb for husky 390 xp with choke assbly removed. if i prime it, it starts and runs great. once i shut it off it won restart without being primed again. im wondering if i should just change the pulse line and fuel line.
Or just shut it down wiff your thumb on the carb.Could give it a lil' squirt right after you shut it down. That would prime it for next time
Check your pop off. May be a tad high.Thank you, I think your right. I opened the low side and raised the idle some more I can now get it to start but it takes two to three pulls which isn't great for competition but it will get there.
