bikemike
- 7:30 AM
- Feb 4, 2016
- Cottage grove mn
That looks like a white ash. Burns good.Cut up the rest of what I believe to be Elm, that my buddy had put down a few weeks ago. I'll try burning it in a few years. It's surprisingly light for its size. Probably about 28". The Dolkita ate right through it!
I questioned that as well. The stuff is very wetThat big bark almost looks like cottonwood.
Yep cottonwood/button ball. Get it dry it'll burn....I questioned that as well. The stuff is very wet
Well if it's dark, you can fix the damage by morning and the customer will never know?Super Crooked
Super Dead back leaner.
Had to set a Line & ease it away from
The Power Lines.
Is it considered Romantic to finish the Back Cut by Headlights?
Cut some wood today one of thise days where if it was goin wrong it did.
Forgot wedges and and had to run back and get them after a dead straight tree wouldnt go over. Fought log oit of deep snow with atv. Tore hitch off . Re welded on and tore it off again on secon last trip with logs. Gonna start from scratch and build a little heavyer hitch.
You have a chainsaw? Cut your logs shorter.
Cut down about 50 or so leaning trees that were the result of a hurricane last summer/fall. Most were dead pines but it was a tangle of dead and live trees, vines and brambles and a dozen spring poles to watch for.
I was intending to test a saw on a downed log and it went from one thing to the other and the next thing I knew I was doing a large unscheduled project. The saw worked great so it will hit my local CL this evening and it felt good to get some saw time in and get all those widowmakers on the ground.
This morning we were trimming grapes in the vineyard. I was using a Stihl hedge clipper for the main trimming and then Groundi came along for the fine trimming and clean up.
Also loaded up my dead lawn tractor which had been on this property for about a year or more. Needs a coil i think. And of course the tires were flat, bead separated on one but I was able to get them inflated and loaded on the flatbed trailer. Now I'm resting after a shower discussing who's going to cook supper since we're both tired...
