Snap 0n Compression Tester
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:28 AM
Provencal, Louisiana
Why in the heck does this thing eat valve cores?? After I check maybe 8 or so saws it starts leaking by at the valve! Help! I get the replacement low pressure valve cores from Napa which is used in their housebrand tester I believe to be made by OTC
ny15
12:28 PM
Lima NY
I had an issue with mine last year and ended up getting the replacement valve core out from Snap On and it's been flawless since. I have the exact same tester as you.
psuiewalsh
Basement Bodging
12:28 PM
Nottingham,pa
Seems odd since the valve part of the core seals on itself.
mdavlee
Hillbilly grinder
12:28 PM
TN
Mine does the same thing. I'm back to using my cheap gauge. They both read the same.
Lee H
9:28 AM
cape cod ma.
Whats the deal Mike? Im about ready to throw this 200$ piece of crap away
Throw it my way. I'll use it. I have the same set but with one more adapter hose. Had it for years and have never changed a core.
Sounds like you might be getting dirt into it somehow.
mdavlee
Hillbilly grinder
12:28 PM
TN
I think I've went through 10 cores. The other day one saw and the core was shot.
mdavlee
Hillbilly grinder
12:28 PM
TN
Didn't the ITT Tech chainsaw school teach you to clean the
cylinder prior to compression testing. :)
It was a new rebuild. All washed up and been run a tank. It was snap on brand cores too
Wagnerwerks
12:28 PM
Pa
You should have the wonderful lifetime snap on warranty no?
Not on that. Only hard line tools get the ltw.
I've heard of this issue before and have always suggested people buy the OTC tester kit. Great deal at 50-60 bucks.
Chainsaw Jim
Con Artist LLC
9:28 AM
Springfield Oregon
I have a cheap $30 one from knecht's and it's been going good for a long time. The last time i used it i forgot to hit the release valve and it didn't leak any pressure after sitting in the drawer for several days.
mdavlee
Hillbilly grinder
12:28 PM
TN
I paid $70 for mine on ebay. First core lasted a year or longer.
