Johnmn
- 10:49 AM
- Feb 18, 2016
- Minnesota
Well my skidder engine went a bit ago. I got a reman engine and it won't run. I have checked for air a million times, tried running it out of a 5 gallon can, replaced injectors, had the pump rebuild, replaced the lift pump, I'm not sure what else. If will fire maybe run for 30 seconds then die. Sometimes flat out die other times it will start to miss first. It seems like it's not getting enough fuel or sucking air through the head. Not sure oh and yes I have checked timing like 3 times. Any help would be greatly appreciated
