fossil
- 4:14 PM
- Jan 1, 2016
- Ontario, Canada
@fossil *s-wordfire, I thought that lump on that tank was suspicious! Does it at least run well now, Tim?
It runs very well. Starts easy. The manual oiler works well but the auto oiler is sucking air from some place. The pump is in good shape, the check valve works and new "O" rings on the pump to saw body. I think it may be the line fitting between the tank and the crankcase. I will pull the rear handle and pressure check the line from there.
Everything was covered in oil in the points box. Cleaning that up and setting the points made a big difference. I think someone may have slobbered oil on the felt oiler.
Thanks again for the saw. I had fun swapping the tanks and getting into the saw. Neat little machines and well built.
