Show off your muffler mods
Sawrain
12:03 AM
South.
Rescued a neglected 036, runs better than it looks.
Anyway decided to get some numbers on the MM.
Exhaust port, didn’t compensate for curvature. ‍
Calculated from app, 302mm^2
Calculated from 27x12mm, 324mm^2
e2d9b45e-294c-4876-9b3d-1271aa4eee1e-jpeg.213560
Muffler openings.
Main opening calculated from app, 315mm^2
Main opening calculated from, 17x21mm, 357mm^2
Calculated total with louvred opening, 358mm^2
3fc02385-7c06-4e2b-95c8-645232748e6a-jpeg.213562
Factory screen has openings,
0.55mm * 0.55mm = 0.303mm^2 each.
Mine has 30 * 36 openings.
1080 * 0.303 = 327mm^2
Could raise this to 380mm^2 with some more grinding to expose more screen, or use a different mesh.
15d49495-2d3b-424b-8297-53dffe1d422e-jpeg.213563
So stock exhaust port at piston,,. 302mm^2
Opened up muffler discharge,,,,. 358mm^2
Total combined screen opening,.327mm^2
Muffler discharge 118% of cylinder exhaust port, (150% looks achievable with more work)
Screen opening 108% of cylinder exhaust port, (125%+ achievable with stock mesh)
The main thing I would like to consider would be the discharge coefficient of the mesh, while it's openings equals 108% of the exhaust port, they may cause more restriction than this number shows due to they way the gasses pass through it.
mdavlee
Hillbilly grinder
10:03 AM
TN
Muffler openings.
Every edge has some flow disturbance compared to one big hole.
Ketchup
Epoxy member
8:03 AM
Colorado
Muffler openings.
That’s cool. What app are you using?
NPKenny
7:03 AM
Lehi, AZ
Here’s one done out of necessity on a previously hacked-up muffler. A good bit of clean-up inside and a scrap piece of rectangular tubing cut to fit for a deflector. The screen is secure and pretty easy to clean / replace.
546C9330-C26E-43F4-B3D3-5D01740C48A7.jpeg 77172451-1D15-4084-8113-AEDABC7F9041.jpeg
Moparmyway
Its just a saw
10:03 AM
In a meeting
My stumping/milling slut muffler mod
The stock opening is closed with a piece of aluminum flashing, easily removed if I want to open it back upIMG_6443.JPG
merc_man
merc_man
10:03 AM
southern ontario
Agent Smith
Hack of all trades
10:03 AM
Northeast ohio
Just finished up this dual port muffler for the 026 project im working on. Welded up the factory outlet inside the cover
Benwa
I love the smell of premix in the morning
7:03 AM
Bow
A little craftsman I did up for a buddy. Some of these have 2 very small louvers for an outlet, on the clutch side, in the rear upper corner of the muffler. They use the partition as the deflector. Nothing crazy, but should flow a little better now. 20200119_011638.jpg
