hseII
AKA - Karenberly's Husband
- 12:20 AM
- Dec 29, 2015
- West Georgia
Looks real old to me ,and never been used so to speakWhy B?
It feels good.
It's a husky carpenters axe Ill have to get a picture in the morning. It is one of the sharpest axes I have and it holds the edge like a champ. Took it to a job taking down a old sugar maple was cutting through branches 3" thick in one swing. Mind you it was green but scared the stuffins out of me none the less!Got a closeup photo of the single bit?
I have this same little axe and I will second that about the sharpness and holding an edge. Good axe and at a reasonable price.It's a husky carpenters axe Ill have to get a picture in the morning. It is one of the sharpest axes I have and it holds the edge like a champ. Took it to a job taking down a old sugar maple was cutting through branches 3" thick in one swing. Mind you it was green but scared the stuffins out of me none the less!
Thanks for the detailed info. I already have a couple draw knives so I guess I better go knock down a tree to get some slabs. I think I’ve got just enough time for them to season before the long dark of winter sets in.You want a draw knife, a rasp or two, wood vice, sandpaper some wedges to get the billet by qaurtering a straight section of wood. Once wood is quartered select billet by looking at the grain orientation at ends of billet. Extract rectangle shape billet from triangle quartered piece of wood. Use the axe bit too act as stencil on billet end by usind a marker to trace handle shape (end that axe bit fits too). Draw knife has two handles with blade in between and has one flat side on the blade so you can shave and shape wood. You need to use a flat saw to cut into the end that the bit goes on so you can hammer a wedge in there. Its a very rewarding experience and takes a little time but well worth it when done. Also some JB weld or 2 part epoxy to seal the end where you put the wedge in. This will keep moisture out. Also if you want to stain it you need that, then finish with linseed/olive oil.
I find if I get a center line, then set head on and trace shape it's a good starting point for me. I band saw the shape of handle then a big rasp to get final shape. Good luck an have fun [emoji38]
I'm old school I guess, I let handle protrude about 1/4in out and cut my on wood wedge an beat it in. No metal wedges for me but I don't really use my axes other than my wedge beater [emoji38]So,
What kind of wedges do you use?
Have you tried those round ones?
They must be cause that's what I'm seeing in new top end axesThat’s exactly what mine are used for.
I’m curious if the round metal wedges are “better.”
I think those round ones are the way to go. I have come across more than a few with the flat metal ones that are loose.That’s exactly what mine are used for.
