- 3:28 PM
- Jan 26, 2016
- South west UK
Thanks that’s a decent size head and it looks a regular size for handle fitment
How are going to clean it up? I have the one and want to clean enough to find the maker but not to much.View attachment 135368 Scored this one today 30$ should clean up nice
That axe looks good it has tidied up well nice jobView attachment 136052 View attachment 136051
Here is a 3 1/2 pound Brazil felling axe I picked up. Clean it up blued it with gun blueing, put a handle in it and straightened the edge where it was sharped on a bench grinder. The handle is a little thin for this axe but it handles great.
A little info on the Daniel Simmons axe. D. Simmons started making axes in 1828 on a anvil near Cohoe NY. And by 1834 he opened a factory in Cohoe between Mohawk river and Champlain Canal, the D Simmons Axe Co. His biggest competition was Collins Axe Co. I had my great grandfather, Mr Shannon come from Ireland to Canada then Lake Champlain as loggers. Their name in Ireland was Shanahan. Any Shannons out there?Would this Simmons be the Axe builder or IC Simmons the hardware store? GoodView attachment 133633 mourning men.
The biggest thing with American broad axe handles is you need a bent handle to keep your knuckles off the log. I would like to use a European broad axe to see how they feel. Many of them had straight handles with the blade at a slight angle to the head. The only European axes with the twisted head I have found here were very expensive. Most people that have one know they are rare here.Thanks that’s a decent size head and it looks a regular size for handle fitment
I have another one that is decent other than a large chip. Has anyone repaired a large chip without reheating and quenching. I can’t fit the whole thing in my forge. And I’m afraid of warping it with a torch.
Is there any thing you can't weld ? Welcome to the axe heads.Preheat a little, tig weld and then quench it in oil, gas, or mineral spirits. I like to use gas or mineral spirits as it leaves less carbon on the part. Yes, it will probably start on fire, so use a long wire or tongs to keep away from the flames and have something to snuff it out handy.
Sure there is... some Stihl cases just can't be welded, made of kitty litter I think.
Thanks I will try that first. I thought about it. I might could use a torch if I had to as long as I just heat the edge and go slow and even it shouldn’t warp. Should have enough meat behind it to hold it still.Preheat a little, tig weld and then quench it in oil, gas, or mineral spirits. I like to use gas or mineral spirits as it leaves less carbon on the part. Yes, it will probably start on fire, so use a long wire or tongs to keep away from the flames and have something to snuff it out handy.
Do you use a temperature stick to get it a certain temp? I tried to stick weld a LB cast alum deck preheated, worked good until it would cool down.Preheat a little, tig weld and then quench it in oil, gas, or mineral spirits. I like to use gas or mineral spirits as it leaves less carbon on the part. Yes, it will probably start on fire, so use a long wire or tongs to keep away from the flames and have something to snuff it out handy.
I'll check that. But do you recomend preheat first? Thanks.For steel it's pretty easy to tell the temp if you have a shinny surface. When it turns from yellow to purple is a good time to quench for a axe, 500-520 F. For an axe you only want the edge tempered, so rapid heating to only get the leading edge hot is necessary.
You probably had the stick welder on the wrong polarity. Most of the time you'll use DCEN for stick welding, but for aluminum you'd want DCEP to get more heat into the part.
