Best Buy Co, Inc. Buy Used Saws CCC Ebay Store HLSupply Daily Deals
Seasoned Vs kiln dried
Discussion in 'Our Firewood Forum' started by Homemade, Jan 8, 2019.
  1. Homemade
    Homemade Pinnacle OPE Member
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    Is kiln dried worth it? Is there a moisture level that firewood can only get to naturally before it won’t go any lower by seasoning/ air drying?
    I seen a video of a guy burning two wood stoves side by side and one with two year seasoned wood and the others with kiln dried. This got me wondering. Could a guy make a kiln out of an old fridge and dry a weeks worth of wood? Use the hot air ducted off the wood fired furnace to dry the wood. Obviously the hot moist air would need to be exhausted outside.
    Just seeing if anybody noticed a significant difference between two.
  2. Homemade
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
  3. Homemade
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    I know in the description it says the seasoned wood is 35% moisture and the kiln dried is 20%. Is 20 low enough. Is 15 or 10% better? Is it worth it for a home time non commercial outfit?
  4. Hinerman
    Hinerman ONE OF THE GREATEST!
    2,631
    10,743
    421
    Muskogee, OK
    That video is a joke. He must be trying to sell kilns or kiln dried wood for much higher prices.
    Seasoned wood is not 35% moisture (2 years or not). Seasoned wood, weather kiln dried or nature dried, is 20% or less. Yes, drier is better, but 20% is 20% no matter how you get there.
    The only advantage to kiln dried is the time to dry and it generally looks cleaner. Is a kiln worth it for a home or non-commercial outfit? Not to me but only you can decide if it is worth it to you.
    SteveSS, Spike60, p61 western and 7 others like this.
  5. Homemade
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    Jeeze, don’t bite my head off.
    Another advantage would be, not needing to stockpile two or more years worth of wood. You could cut just for the coming year or even cut as you need it and just dry it before you burn it.
    CrystalRiver1 and Cat 525 like this.
  6. Ryan Browne
    Ryan Browne Pinnacle OPE Member
    Sep 4, 2016
    1,476
    5,557
    325
    Wisconsin
    I'll assume you're talking about wood for your planned Lamppa furnace, so I'll relay some info from them. They recommend burning wood with a measured moisture content between 18-28%. To me, the high end if that range seems very wet, but Dale was saying that wood that a little on the green side contains more volatile liquids that can be burned in their "gasification" furnace. I have heard similar info from the guys running high efficiency gasification fireboxes in the maple syrup industry, though those setups use high pressure forced air, so it's not exactly the same.
    I mentioned that I had just finished cutting 4 cords of fresh red oak and planned to burn it for the 2020-21 heating season. He suggested burning it next winter instead, which to me sounds crazy, considering that it's oak. Also, the sticker on the front of the furnace actually says that wood should be seasoned, and then clarifies that it should be cut, split, and covered in April or May and burned that fall and winter.
    So, take that for what it's worth. Sorry I haven't given you a ring yet. Haven't forgotten, just been busy.
    Cat 525 likes this.
  7. Ryan Browne
    Sep 4, 2016
    1,476
    5,557
    325
    Wisconsin
    I will also say that in our conversation Dale said that the Kuuma has no problem burning pine or other softwood, but then said that he thought burning Ash was useless saying it had less BTUs than burning toilet paper. So, while the man is very helpful and knows the product very well, I would say that hopefully he's not right about everything. Personally I burn a fair amount of ash and find it to be a great firewood.
    Marshy and Cat 525 like this.
  8. angelo c
    angelo c Larger Member
    2,041
    7,885
    383
    For me, kiln drying is for killing bugs and stuff for specific clients who need "bug free" wood.( Kitchens ect) there is only so much moisture "kiln drying" can eliminate as it will re-absorb moisture from the environment in short order. I think for your specific burner/flue/environment/ use/ demographic..... yes just gotta see what works best..... for you(and your budget:) )
    Philbert, JimBear and Cat 525 like this.
  9. Homemade
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    Yes Ryan. I was planing on using it with my Lamppa. It never crossed my mind that the volatile liquid (sap) will aid combustion and count toward the moisture content. So maybe 20% is an ideal ratio. All the h2o gone, but still enough sap to burn better.
    Cat 525 likes this.
  10. angelo c
    2,041
    7,885
    383
    I have a close friend who is an engineer and works with other engineers....one of his co-workers gave me a long dissertation once on why "green" wood burned better then "seasoned". I shrugged and refused his thought processes and math-nastics....my buddy burned "green" for a few years until he almost burned his house down from a chimney fire. Destroyed a $30k full masonary fireplace. But hey, we are adults and we get to do as we choose.
    CrystalRiver1, JimBear and Cat 525 like this.
  11. sixonetonoffun
    sixonetonoffun Well-Known OPE Member
    Dec 25, 2017
    84
    155
    78
    Mn
    I think the green house idea would be cool. Just not fond of another structure to maintain. But if a wood shed was needed some southern faced orientation and cheap clear poly panels on the roof and siding. Some clever venting wouldn't be hard. Could speed drying I think.
    The seasoned wood of yester years just ain't cutting it for some of these EPA stoves.
    Cat 525 likes this.
  12. Philbert
    Philbert Chainsaw Enthusiast
    Jan 30, 2016
    1,969
    6,951
    325
    East Dakota
    Kiln drying is needed to transport wood in some areas, due to invasive insects. Keeps them out of your house too.
    Other reason might be to shorten lag time between cutting and burning, especially, if you have limited space to let wood season for several years.
    Could become a hobby, with a greenhouse, etc. Some guys talk about making a kiln out of shipping containers, with fans to move the air.
    Philbert
    Cat 525 likes this.
  13. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    2,755
    8,431
    340
    Mexico NY
    Seasoned wood at 35%? WTF? That is NOT seasoned at 35%. Is the guy smoking crack? My seasoned wood is 20-25% moisture after one year. That's soft maple and ash. Oak and locust is still around 30% after one year. I've never seasoned for 2 years so I cannot comment on how low it will be in 2 years. Most of what I read was 15-20% in 2 years. Feom what I've read 10-15% moisture is about the best you can do without a kiln and probably on the high side of that range.
    Is it worth it to kiln dry it? No! How could it be worth it when 15-20% is exactly what modern EPA stoves are calling for? Even with 20-25% I do not see any I'll effects from the moisture. I'm sure diminishing return comes into play. I cant see how kiln drying it will be worth the cost unless you have a passive solar kiln. But if it involves using electricity or burning a fuel I cant imagine it is worth the return. The only exception to that is if you are selling bundled firewood and it has to be kiln dried to kill bugs.
    Cat 525 likes this.
  14. Nutball
    Nutball Well-Known OPE Member
    Oct 31, 2018
    167
    283
    98
    Mt. Juliet, TN
    I don't think wood can dry out anymore than the surrounding air, at least not without heat (kiln drying). But after kiln drying I'd expect it to suck up the surrounding humidity again if not used soon enough.
    WKEND LUMBERJAK, Cat 525 and angelo c like this.
  15. Ryan Browne
    Sep 4, 2016
    1,476
    5,557
    325
    Wisconsin
    I do think that if you could do it in a cheaply built hoop house that it could be a good selling point. I am close enough to Minneapolis/St Paul that there is a pretty good demand for firewood at a premium price.
    So far I've been able to easily sell whatever excess I have just by mentioning that I'm not out to screw my customers and stating how long the wood has been drying. But I'm the future if I ever have trouble selling wood, I imagine that saying "kiln-dried and bug free" in the ad would be an easy way to separate oneself from the competition. It certainly wouldn't be that tough to toss it into a greenhouse for a couple weeks before delivery, and I imagine that I could probably tack on another 40-50 bucks a face cord.
    sixonetonoffun and Cat 525 like this.
  16. Philbert
    Jan 30, 2016
    1,969
    6,951
    325
    East Dakota
    Check with the DNR about certifications and labeling.
    Philbert
    "MDA Heat Treatment Certified means the company operates a kiln that has passed a rigorous inspection and testing process and has successfully demonstrated the ability to heat their firewood to a minimum core temperature of 140˚F for 60 minutes.
    MDA Kiln Dry Certified means the company operates a kiln that has passed an inspection and testing process and has successfully demonstrated the ability to heat their firewood to a specified temperature and final moisture content, dependent on the size of their firewood pieces. This certification is limited to wood that has a maximum thickness of three (3) inches, and thus is primarily used for lumber, but may also be used for firewood kindling of the appropriate size."
    https://www.mda.state.mn.us/plants/pestmanagement/firewood/firewooddealers
  17. Ryan Browne
    Sep 4, 2016
    1,476
    5,557
    325
    Wisconsin
    Interesting, and thanks for the link. I actually don't cross into Minnesota for firewood sales. I stay within 25 miles of home; i don't want to risk spreading anything and I deliver with a 454 powered truck :). I just mentioned the cities because there's enough io a population with enough money to support selling "premium" wood. I don't ever plan on selling more than 15-20 cords a year at the most, so I doubt I'd ever seek state certification. It would be pretty cool to know how long you have to heat a stack of firewood for the pieces to meet 140 degrees. I imagine that a hoop house could get that hot on a sunny day but I'm not positive and you'd also be limited by daylight hours.
    sixonetonoffun and Philbert like this.
  18. Marshy
    Marshy WFO Cutting
    Jan 5, 2016
    2,755
    8,431
    340
    Mexico NY
    I agree with what you are saying. However, a solar kiln is not the same as a traditional kiln. To kill bugs the wood has to be subjected to a certain temperature for a sustained period of time. I dont know the specifics but I do know its unachievable in a solar kiln without an additional heat source.
    Edit: I see Philber has listed those specs!
  19. Homemade
    Apr 8, 2017
    619
    1,492
    203
    Wisconsin
    I thought they just lowered the bug killing temp spec too. IIRC, I believe it was 160 degrees f for 60 min.
  20. blades
    blades Well-Known OPE Member
    Aug 30, 2018
    14
    27
    48
    Leroy, WI
    WI. DNR has a certification program for kiln dried firewood. That said, it is more on the order of bug killing than actual drying to a specific %. My notes on this subject suggest that 30 days at a sustained temp of 140-160 deg is needed to get to 15-20% moisture content on 4-6" splits and that it varies with the type of wood. Kiln dried furniture wood is taken down to apx 6-8% ( most of that is 1" thick ) when it is removed from kiln and set aside. At that point the wood will rehydrate/ stabilze to apx 12-15% (under very adverse conditions those numbers could increase).
    12% and below is a bit too dry. The wood will burn like a match stick, 13-18% is about ideal in our EPA stoves. It is very easy to tell in a tube stove when the wood has too much moisture content as it takes forever to fire off the secondary's due to the cooling effect of the moisture being driven out of the wood by the heat of the fire. With experience you can somewhat tell by the flame color as whole, Dark orange is a cold fire , a bright yellow with blue tints is hot. Also you need apx 1100 degF at the tubes for the gases to ignite and enter into a sustained secondary burn. NC 30 a lazy secondary burn sustained will net apx 450 degs at the step with an IR gun, raging jet action all 4 tube blasting will net 650 on up, if you do not close off the control it will run right past 700. Sustained temps 700+ is not good for this particular stove. Any of the moisture meters will give you a general idea where you stand moisture wise provided they are properly used- most in-expensive units are pre-calibrated for furniture type woods. Item to be tested should be opened up so a freshly exposed face is used, item should be at room temperature though out ( room temp generally 60-75 degF). for our purposes the difference is in-material between types of wood. Well any way hope this is of some help.
Loading...
Similar Threads - Seasoned kiln dried
  1. junkman
    96
    3,418
  2. TimRD
    15
    1,021
Share This Page
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
