Liazard
OPE Member
- 5:40 AM
- Nov 7, 2017
- South FLorida
KM-55. In the Stihl repair manual it says to use screwdriver 5910 890 2420 to remove the nuts that hold the air filter housing on. The tool number is represented on Amazon by "carburator adjusting screwdrivers" that are way too small. The nut looks to be about 1/4".
The nut is in a plastic tubular thing and screw onto a protruding threaded rod, which apparently also hold the entire carb on (photo attached). I have the feeling that a 1/4" socket that's deep enough to extend past the threaded screw will be too thick to fit between the plastic tube and the nut.
Does anyone know what I need to remove these nuts?
