Looks like the shipping dept needs to clean up some of those boxes lol.026 I thought I finished yesterday. My second oem seal failure ever. This one leaked between the oem bearing and the seal. Was installed the same way I do them all the time with factory seal tools.
Couldn’t tune idle, was all over the place. Was fine, then it wasn’t, then it was. The sure fire sign all isn’t well and there is likely a leak.
Went from looking like this
View attachment 165723 View attachment 165724 View attachment 165725
Back to this
Back to this
Just what it was.Outer portion on the seal maybe out of round? It happens. I experienced a "batch" of 4T40 transaxle seals like that.
They would drive in fine, look fine, but leak around the outer perimeter of the seal.
Must have been stepped on at the factory.
Just what it was.
Touched up a 25" square chain. Full comp RS 3/8 squarefiled. 7 pin. Gonna refire saw and load it up.
I like to torture test a saw before it leaves. Less cost and headaches than trying to right a mishap.
View attachment 165947 View attachment 165948
Stay tuned for an annoyingly long typical Mofo Video.
were you 2 cutting farts? Cuz I didn't see any logs?
@StuntCockWelder at it again....
ported 365special. Sounds good! Oils the concrete more that the exon oiled the ocean.
you need to get some .404 action on them.Just what it was.
I like to torture test a saw before it leaves. Less cost and headaches than trying to right a mishap after the owner receives it.
Here it is. I thought maybe another airleak, but there is an issue with the spring and switch on the saw. I also think it just got hot. Its tuned to 13800 and actually held 10k in the cut at times with light pressure.
The second vid was really just to check idle. Its getting boxed up and i wont miss it one bit when it leaves.
View attachment 165985 View attachment 165986 View attachment 165987
You said whilst...I think it’s kind of Homo sitting in a shooting shack with a Milwaukee electric heat coat & talking smack about wrap handles whilst shooting a “you’re #1” selfie: but mainly the smack talking about wrap handles.
LOL! It was 9:15 at nitewere you 2 cutting farts? Cuz I didn't see any logs?
Why ya gotta be flipping up the bird?
Oooooo das nice!!!
