- 7:21 PM
- Dec 30, 2015
- Brewster, NY
That is correct. Higher Octane ignites at a higher temp, allowing for higher compression, but in the same engine it will burn cooler (but have a longer burn time).
It will only produce more power in an engine designed to use it (or with the proper computer controls).
Which leads to an interesting question ... would a M Tronic saw make more power with high test fuel (by providing more timing advance)???
Stihl generally recommends a minimum of 91 octane stating that the higher octane will run cooler.
