- 12:27 AM
- Jan 24, 2017
- Berkshire County, Massachusetts
It might be half a pound heavier than a 460 with better antivibe (why I chose it).
Don't forget way better air filtrationIt might be half a pound heavier than a 460 with better antivibe (why I chose it).
Runs great!!!Only lowered the transfer walls flush to base on this 51.4mm and the hump remains in the transfers and matched lowers to the case. No base gasket. Running a 365 Zama. It turned out better than I thought it would. It runs a 28 8 pin all pissed off. View attachment 83640View attachment 83639
Yeah, service intervals and fuel consumption was also a factor. Some folks complain about the weight but don't factor in some benefits that make it a better work saw. Ain't gotta clean the filter nearly as often. And it sips fuel.Don't forget way better air filtration
This saw is begging for bigger wood. It really wants to run.Got to run @Glock37 MMWS 044 Hybrid today. Running a 20" bar and I believe factory Stihl square ground chain with a 8 pin rim. Here it is!
Sure is!This saw is begging for bigger wood. It really wants to run.
I ran glocks hybrid at the pa gtg and it is one bad mofo. Lethal with a 25 inch bar buried.This saw is begging for bigger wood. It really wants to run.
it's a stihl no wonder lolThe saw that impressed me the most yesterday.
It can breathe halfway decent with those mufflers. Not as loud as I expected eitherThe 084 sounds better than stock Mike. Nice job with those mufflers. [emoji106]
