Lightning Performance
- 1:20 AM
- Jan 26, 2016
- East of Philly
Do this.Thank you all. I understand that it's way more than numbers I was kinda looking for a "base line" to go buy. But I do understand that it's different for each saw. I will do much more research and read the posts you provided. Thanks again.
Keep your base gasket. A tuning trick is to remove it and test again. You need help from guys who build Husky saws, I don't. The flow is always more important than the numbers. Things work in balance with the next piece. It sounds stupid but the "tune" when nailed just sounds like a symphony. Nothing strained or pressed.... it just flows out smooth power evenly and never seems to stop pulling. That applies to anything well thought out and correctly feed with proper timing.
Edit: for poor spelling and punctuation
Friday October 18th 2019
And I'll add that everything has a ceiling and breaking point or failure.
